Air fryer thread
leedebs
Ta
Just a generic Morrisons supermarket one taken off the shelf while queuing for a till on Saturday.
No screen, no lasers, just a basic air fryer.
Ta, have a local Morrisons near me might check it out. Does it have a name or model, price?
Thug
Looking at the Corosi one on Amazon as seems to get good reviews. Anyone on a low fat diet use these, worth it? What about using frozen chips in this, would that work ok?
If you read through this thread you will see a few of us have this make.
I love it and use mine about 5 times per week.
razy60
Low fat diet not so much, it is healthier though, it does oven chips better than a oven, you just need to adjust your temps and time slightly.
kBm
Air fryers are designed for frozen chips! :D
15 mins from the freezer and you're done. I much prefer using frozen. Tried making chips from scratch but i was disappointed, not worth my time and effort.
Now, homemade paramentier potatoes (roast cube potatoes) drenched in garlic butter come out a treat.
kBm
Are there any accessories worth buying for it??
I got the Cosari accessory kit which should fit most air fryers. Is it worth it? Probably not. The baking tray is nothing more than a small cake tin ( which i have plenty of). However the little rack is very handy.
Recently i got a cheap silicone 6 hole muffin tray, cut it so i now have a 4 hole muffin tray that fits in the air fryer. Its perfect for homemade Yorkshire puddings. The air fryer is alot easier to get the oil really hot.
mitch
Ooh got a recipe for those potatoes?
kBm
Based on this one, but following the guides here for homemade chips.
I cut the potatoes really small, dried them well, and used crisp and dry with garlic powder. It was around 180, for about 15 -20 mins with a proper shake up every five minutes. I used my own garlic butter, but any ready made butter will do.
I'll be having a go a patatas bravas next.
mitch
Let us know how you get on.
razy60
For those that are interested and or like this sort of thing, apparently there is a smart version of the Cosori it has a smart home app. Ther is a really good app for recipes its called NutriU (Philips) in the Play store.
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
