Question Air fryer thread
Hixs
@Thug
Bought the fryer you recommended. Used it for the first time today to do some chips (skins on wedges) but they came out a little dry using the chips program. Do you need to adjust the time if the basket isn't full?
MisterRigsby
@Thug
I just check mine every five minutes. My fryer doesn’t stir the food so I need to shake the chips anyway while cooking.
My method:
Chop potatoes to size required. Wash chips thoroughly in cold water to remove starch. Dry chips in a tea towel. Leave in fridge for an hour or so to dry out more. Coat lightly in rapeseed oil. 200deg in fryer, shaking and checking every five minutes.
Hixs
Ah, see I didn't do anything with the cut chips except lob them in after the pre-warm was finished.
Pre-preparing chips comes across as a bit odd to me tbh. They're suppose to be a quick food :/
busterbenny2001
First use tonight. Basic chips agony..... waiting to see what they are like. Beeping
3 and a half hours and no update.... agony :) how were they ?
Don’t fry chips much but kids eat a lot of oven ones interested in how these compare.
Inferno
I have a Tefal one and basically it only does chips and roast potatoes, when i do chips all I do is peel the potatoes and chip to the size I want, then rinse them off to remove the starch in a bowl under cold running water, drain in a cullender and shake , then just place them in the fryer for 5 mins then lift lid and add a half scoop of veg oil and further cook for another 25 minutes and they come out as I like them, a little crispy and soft in the middle, dead easy!
I am now looking at a better/different one that I can do more in as in Steak and other stuff like chicken, one with a rotisserie will do, there is a few on The Zon, Anyone any recommendations or experience with one?
Thug
@Thug
A little late to reply here (that's 12 hour shifts for you).
As already said, cut them, wash them (for as long as you can), then dry them before cooking them, for a 'basic' chip.
My regime, if wanting special thick cut chips is to wash them, cut them (skin on), boil them for 5 mins, drain them, lay them out on kitchen roll and allow the steam to come off and dry them.
I then place them in a bag with a spoonful of frylight and agitate the bag as the frying is preheating, then put them it. I check them and shake them every 10 mins.
Yes, this is a chew on, but they are the best and you can boil them hours before you need them if you want.
MisterRigsby
Southern fried potatoes tonight. Yum.
Maris Pipers peeled chopped and thoroughly washed to get rid of starch. Boiled for a little while, until a knife easily slid in. Left to cool and dry in the fridge. Tesco’s had ‘roast potato coating’ and ‘southern fried coating.’ Couldn’t choose so bought both, 60p each. :) Coat lightly in oil and tip a load of each coating in, thoroughly covering. Cook at 200dg until crispy on outside. Bloody lovely. :thumbsup:
Barbs77
Tried this last night and very nice they were too. Today's trial baked potatoes started in the microwave finished in the air fryer... perfect.
Thug
Tried pork belly today and was a little disappointed in the skin not crisping up as mush as I thought it would.
Perhaps it had a little too much fat.
Still tasted great though.
Asparagus is another great food to fry in the air fryer. Just put a little oil, salt, pepper and garlic powder on them. Lovely.
Thug
MisterRigsby
Is anyone able to recommend a a model that would be suitable for 1-2 persons. Ideally no more than a £100.
I was going to get the one Thug has linked to above but the price spiked when I was looking to buy - went up to nearly 100 quid. ‘Cos of that I got a Tower one from Tesco for 50 quid. Seems to do the job well enough. Model number is Tower T17024, now 45 quid at Argos. It’s got digital timer and temp control. They do a mechanical timer model for a tenner less.
I really must experiment a bit more with mine rather than just making chips all the time. They’re a useful gadget.
MisterRigsby
I’ve made more chips and refined my method. :)
When drying the chips in the fridge after washing, I leave them wrapped in the tea towel. This drys them out even more. Dry potatoes in, mean crispy chips out. :smashin:
Thug
I’m sat here now reading this whilst eating air fried chips with chicken curry.
I just cut them, washed them, dried then with kitchen roll, oiled them with 'crisp and dry' in a bag then cooked them for 35 mins.
Very crispy and very lovely.
Kailash
^ that's all i really do in mine, chips! if you can get the Garlic wedges sachet you can add some flavour to them
best thing is you don't feel like it's unhealthy at all when they are air fried
techsavvy232
Been thinking about getting an air fryer and have no idea about them at all.
Are they worth getting?
Which one would you recommend?
Been looking at this one https://www.amazon.co.uk/COSORI-Electric-Portable-Reminder-Function/dp/B07GBQFNT9/ref=sr_1_2_sspa?s=kitchen-appliances&ie=UTF8&qid=1549866207&sr=1-2-spons&keywords=air+fryer&psc=1#
This actually looks like a good one. I've been looking at this one and the looks the same but the COSORI fryer looks more refined. I bet it's pricier too. Will be looking for cheaper ones, but glad I stumbled upon this thread!
Thug
The Cosori has been reduced on Amazon to £59 from £89.
Its a no brainer at this price.
https://www.amazon.co.uk/COSORI-Electric-Portable-Reminder-Function/dp/B07GBQFNT9/ref=sr_1_2_sspa?s=kitchen-appliances&ie=UTF8&qid=1549866207&sr=1-2-spons&keywords=air+fryer&psc=1&tag=av0c-21
mtenga
When do people add oil to their chips?
From the start or mid way through cooking?
I've just worked out how to use the cage on my VPCOK fryer and keen to get chipping.
I soak mine in water first for an hour before drying them. Apparently some health benefits to that and better than just washing.
mtenga
My half chunky chips turned out really nice. Soak for an hour, dry, oil, add to basket and then maximum temp 240c for about 25 mins. I tried doing at 180c to 200c as suggested elsewhere but they never really got cooking. Might be my inefficient unit.
Thug
I wash mine, dry them, then place them in a bag with the oil and agitate the bag to coat them all, then throw them in the Air fryer.
mtenga
I've got one of these coming today. Managed to get it for 60
Got sick of burning my hands on my last one and look forward to using a basket instead.
SuperOwl86
Finally bought the Cosori linked earlier in the thread and just tried to do some chips, for a first time go they was ok but some were more like a crisp.
Any tips would be much appreciated.
Thug
What did you use (obviously potatoes)? How did you prepare them? How did you cook them?
For fairly basic chips, whilst the air fryer is pre heating, I cut the potatoes approx. 1cm square, wash them (usually under running water in a colander) then pat dry them. I place them into a bag and put a little crisp'n'dry on them and agitate the bag and then put them in the air fryer pressing the chips setting. I always add an extra 5 mins to the time. I shake the basket every 10 minutes and they work out great.
If I want to make them a little more special I will cut them a little thicker and boil them for 7 mins, then spread them out on kitchen roll to let the steam come off to dry them.
I will then put a coating on like southern fried or garlic and herb. I will air fry them the same way as above.
Just make sure you shake the basket (releasing it from the base will make it easier), the more times the better.
mtenga
The Tidylife fryer I linked to a few posts above was no good, so replaced it with a Philips.
You can get it cheaper if you look around. Gets a bit smokey but recommended based on my early experience. Chips and belly pork slices worked out well.
nick67
Interested in an AF, how are people getting on with the Corsori, has anyone opted for the larger version?
Thug
I am totally happy with the smaller one, but of course a little larger would be better (so my wife said).
The only issue is its larger to store.
There are 3 of us in our house and its fine, but larger may also cook more evenly too.
If buying again, I still don't know which I would buy or prefer.
Similar threads
Trending threads
Latest news
What is Contrast Modulation?
  • By Steve Withers
  • Published
Samsung applies for Q-Symphony trademark for TVs and soundbars
  • By Andy Bassett
  • Published
Best Hi-Fi Products 2019 - Editor's Choice Awards
  • By Ed Selley
  • Published
McIntosh releases DA2 Digital Audio Module Upgrade Kit
  • By Andy Bassett
  • Published
Sky TV offers cheaper Sky Q box with updated features
  • By Andy Bassett
  • Published
Latest threads
