Air Duster supply
Discussion in 'Projectors, Screens & Video Processors' started by RobsterD, May 14, 2004.
  1. RobsterD
    RobsterD
    Dec 11, 2000
    891
    Southampton
    +12
    Hi Guys
    Quick one where is the best place to get an Air Duster I need to remove some dust blobs on my AE500,I bought a Maplin air duster PN N60AN,
    but this leaves a residue from the propellant or would seem to,though it does go or dry out,so I'm a bit unsure wether this would be suitable.
    Any links appreciated.
    Rob
  2. Jonny1973
    Jonny1973
    Don't they all do that???
    I have a can from PC World, the liquid squirts out if you hold the button too long, too close.
    Maybe you should use short bursts from further away.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,529
    Somewhere in South Yorkshire
    +6,000
    I've used a Maplin one on my Sony without problem. But you do get a bit of liquid if you hold the can the wrong way up, or get it too close. Practise on a mirror before attacking your LCD panels.
  4. calibos
    calibos
    Aug 4, 2000
    940
    Ireland
    +33
    My local Tescos do the vivanco air duster. Same shelf as the DVDR/CDR blanks etc
