air con issue
Discussion in 'Motoring' started by GalacticaActual, Mar 10, 2013.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Hi all.
    I had my condeser on my car air con replaced just under a year ago and the air con had stopped working again . If you look at the condeser they is a horizontal line of tracer dye running across the front of it about a 1/4 way down from the top. Is it possible that a new condenser could be faulty like this , or could the gas from the air con have sprayed on to it from somewhere else ? . It is a 2l w plate focus .
  2. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    difficult to say without seeing a picture , but i suspect its knackered , and finally , of course a newish part can go south quickly , was it new though , or a recon , if you can get such a thing of course ...
  3. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    I an pretty sure its new . It still looks uncoroded , thinking maybe it just wasn't built properly ?
  4. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    is it at the front of the engine? Stone chip damage?
  5. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Yes , its at the front of the engine , and I could be convinsed it was stone chip if just in a couple of places, how ever its in a straight line right across the front of the condenser and not just in a couple of small places .
  6. rongood
    rongood
    Jul 20, 2003
    3,344
    herts
    +270
    If the garage decide its a stone chip leak your out of luck, you can have a new condenser fitted drive up the road and bang.....gone again by a random stone.
    We had almost the same in the works connect van and had to pay up again.
    We went to Ford for the first repair but had it done by one of the mobile air con fitters as they are much cheaper for parts and re gassing, always get an estimate first as well mate by whoever.
  7. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    So I may just have to swollow it then and get it redone . What's to stop it happening again ? Cab you get re enforced condensers that are stone proof ?
  8. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    Could you fit some sort of mesh in front of it ? ...
  9. rongood
    rongood
    Jul 20, 2003
    3,344
    herts
    +270
    Yup could have a newun fitted (dont go to Ford) and go down the road......Bang gone again, would be unlucky though but could happen.
    Nothing is 100% but what could help is some mesh like THIS very small stones might get through but it would stop larger ones and might take the sting out of the smaller bits.
    It also looks good as well IMO.
  10. IanW1977
    IanW1977
    Dec 30, 2002
    4,580
    West Midlands
    +484
    Yeah as it's gas if it gets damaged it's dead - Ours lasted about 8 months before getting damaged. it's down to luck
  11. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Just to revive an old thread, but would you belive after getting the blooming thing repaired last year, I have stone damge again on the new one. I dont do many miles, but if I get it reapired again, this will be the fourth condser that I know of that has been fitted on the thing!
  12. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Does anyone know why the air-con is now blowing colder air through the drivers side vents than the center and passenger vents? I got the previous problem fixed but now this is happening!
  13. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    It suggests that some part of the diverter assembly isn't, diverting that is....
  14. car-man
    car-man
    Mar 18, 2008
    2,185
    116
    +1,436
    I don't know about your car, but my Peugeot 407 has a fault common on the 407 where the flap inside the heater assembly for any one side can break and cause the climate control to only work on one side...mine needs fixing :(
  15. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Is fixing the diverter an easy inexpensive job ? Is it likely that the drivers side will eventually stop working ?
  16. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Is this any easy fix of would i need to go to a garage?
  17. Exemplar
    Exemplar
    Apr 4, 2005
    5,121
    3
    Newark On Trent
    +1,474
    How old is the car?
  18. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    Old....., W plate.....
  19. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Yes it a w plate so 2000/ 2001 i think. still in very good condition though, (apart from this issue!)
  20. paulyoung666
    paulyoung666
    May 4, 2006
    13,510
    Teesside
    +3,841
    Guessing this has twiddly knob controls, they will pull on cables, Wroxham would suggest one has detached itself and a flap is sick in position, try turning said knob in a quiet environment to see what you can hear or not hear a the case may be....
  21. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Also after checking the temperature at the one vent that is cool, the temperature only goes as low as10 degrees C, is that right or should it be lower?
  22. IronGiant
    IronGiant
    Jun 7, 2003
    65,924
    +45,929
    For an old car I'd say that wasn't at all bad...
  23. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Yes but it was only repaired and re gassed back in april
  24. _Dragon_
    _Dragon_
    Sep 29, 2008
    1,664
    63
    +144
    Shouldnt they all go down lower than 10c no matter the age? Mine cools down to 10c then takes ages to get to 7c,if i want it to reach 5c then i have to turn the fan right down,have you tried turning the fan down?
  25. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    When you say turn the fan down do you mean reduce the speed of the fan to a lower setting?
  26. _Dragon_
    _Dragon_
    Sep 29, 2008
    1,664
    63
    +144
    Yes thats right reduce the speed then test.
  27. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    why would less air coming out at a reduced speed be cooler?
  28. _Dragon_
    _Dragon_
    Sep 29, 2008
    1,664
    63
    +144
    More air going over the evaporator more time to cool the air.
  29. IronGiant
    IronGiant
    Jun 7, 2003
    65,924
    +45,929
    The slower the air flow the longer it is in contact with the cooling fins and the colder it gets. I'd keep an eye on it and if it gets any worse take it back.
  30. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    6,109
    Galactica C.I.C.
    +346
    Thanks guys , will keep a close eye on it and see what happens
