agh DIVX problems driving me potty.
Discussion in 'Desktop & Laptop Computers Forum' started by MikeKay1976, Jun 11, 2005.
  1. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    7,656
    +1,659
    i am sure this is a common problem. many of my divx files are encoded to run at different fps.
    ones which run at 30fps are fine @60hz
    25fps ones run ok @ 75hz refresh rate (the plasma doesnt like 100hz)
    & there are some which are 24fps which i have to run at 72hz.
    the problem is is that this is a right pain in the ass for anyone in the house except me who is computer literate.
    is there any software i can use to analyse the fps on the divx file & atomatically adjust the refresh rate so that it will play smoothly?
    i also still cant get tv running smoothly using descaler :(
    if i run no other software its not too bad, but as soon as i log in on my other account & do some downloading the framerate drops.
    bugger :( can anyone help?
    (Athlon XP 2400+, 512mb DDR 200mhz dual channel ram, TNT 2 m64 (was using the onboard geforce 4 mx graphics of the nforce 2 but thought a standalone card would be better)
    divx software ffdshow with Any dvd
  2. stlic
    stlic
    Feb 17, 2004
    762
    +19
    If your happy using reclock (everyone should be IMHO) then it has a handy feature which will do just what you request. Feed it some powerstrip frequencies and it will analyse the video and set the refresh rate accordingly. I use it to change from 24 to 25 Hz interlaced depending on source; 30Hz not supported on my TV but I rarely need to use it.
    Not sure about dscaler as I've never used it more then for testing.
  3. gktk
    gktk
    Aug 26, 2003
    103
  4. MikeKay1976
    MikeKay1976
    Feb 1, 2005
    7,656
    +1,659
    cheers guys......... am sure that info will help
    M.
