After some small amplifiers
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by tbguk2, Nov 24, 2004.
  1. tbguk2
    tbguk2
    Nov 24, 2004
    46
    Long time watcher, first time poster :)
    I'm in the process of doing my whole house audio - and I need to source some amplifiers.
    I'm using a PC soundcard (with 8 outputs) and I need to boost these before going onto the room ceiling speakers.
    I have 8 zones - 8 rooms. And I'm really trying to find some small cheap low power amps - these are for convenience not quality. For quality I go to my cinema room which has had a tad more money spent on it.
    Need to be small - cause I need 8 and they have to go in the rack. Cheap - cause I dont feel I need to spend a lot of money on these - and I need 8 !
    Any recommendations out there ? Just need 2 x phono in and then I can wire the speakers into them.
    Something good may be say a 10/20W amp, and less than £50 !
    TIA !
    G. :lease:
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,902
    The Borders
    +3,122
  3. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    68
    Leicester
    +56
    Pro audio places like Digital Village should be able to do you a 1u 2 channel power amp for under £100. Another option would be to buy 3 identical 6.1 receivers that have a 6.1 input which would allow you to access 3x6 channels of power. I can't remember which budget amps/receivers have a 6.1/7.1 input but you should be able to get suitable ones for just over £200 each and they'll have some resale value if your system changes. If you could get by with just 6 zones you'd only need to buy 2 but if you need all 8 then you'll have some spare so you could even run full surround sound in one of the zones.
  4. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    68
    Leicester
    +56
    Just got an email from Maplin and they've got a ProSound 12 400Wmax Code QZ29G £74.99 due in 14 days. Thay've also got a 5.1 amp L55AK for £49.95 but the power and freq response is limited on the centre ans surround channels. If you used these I'd buy at 4 and ignore the centre channels and only use the suuround amp channels in the least important rooms. But at £200 this must be the cheapest way to get amplification for 8 zones (16 speakers).
  5. iainshaw
    iainshaw
    Gareth, did you resolve your question. I'm facing exactly the same issue and it would be great to know what you went with
    thanks
    Iain
  6. Arcahngel
    Arcahngel
    How about buying 4 old japanese integrated amps from ebay. Inelegant, but cheap. You can also get some damned decence kit for silly money, simply cos they are more than 5 years old.
    Archey.
