After advice on buying a Balanced Mains Unit or Mains Conditioning kit.
paulguk
Earlier this year I upgraded my amp and speakers. Generally I love the sound I get but sometimes, typically in a weekday afternoon the sound can be flat, lifeless and often have a sibulance in the mid range.
I have good mains cables and extension (Russ Andrews). I have been reading a lot of reviews and forum posts and they all discuss either trying mains conditioning or a balanced mains unit.
I have looked at the Russ Andrews PowerPurifier fully loaded
and this BMU
I welcome advice from members who have tried either of these or similar.
many thanks
gibbsy
The UK electrical supply is pretty damn good and there really should be no need for an overpriced mains conditioner. It's electricity, it's not magic. If you're having trouble with the electricity in your home then have it checked out by a sparky.
I got three amps running off an extension lead that I bought from my local Screwfix for £12.95. If anything your remark that some afternoon listening is flat and lifeless goes to prove that the expensive Russ Andrews cables are not doing the job you hoped they would. Doesn't that set the alarm bells ringing with you. No you want to throw good money after bad.
MaryWhitehouse
Hokum and nonsense lol
Hixs
Partially agree with ol' Mary...
In any devolved country sh*te like this really isn't a requirement, but if you live in the developing world where 24/7 electricity is still a bit of a luxury then maybe worth a go.
MaryWhitehouse
Apologies was assuming uk as profile doesn’t say. I appreciate in the developing world and US :D these have a place.
MaryWhitehouse
In that case I’ll stick with hockum and nonsense then.
Hixs
Aye...
Even French wiring can handle hifi, so you're ALL good in the UK (cause French electricians suck)
D
Deleted member 24354
Why do HiFi enthusiasts (I refuse to use the A word) all think their hifi, needs special ‘electric’ to run on? Do you not think of the designers thought it needed a magic juice box to work ‘properly’ that they would fit one? I work in a 5 $Billion Dollar Space / Aerospace / Military engineering co. and have never yet had an engineer ask for a mains conditioner. We build amplifiers and power amplifiers with more precision and value than the entire value of the whole of AVFs readership’s HiFi combined - still gets built off mains voltage, no magic doohickey. Please do yourself a favour and get a reality check. Oh and the IEC cables, CPC or Farnell, fiver each. NASA and ESA don’t do Russ Andrews 😉
dannnielll
Gibbsy, has the right in this. Any of the complaints about mains tends to come from USA based contributors. My belief is that the standard USA mains of 120 Volts is incapable of supporting the high power requirements of beefy amplifiers, And the 220v supply is only available in their laundry room. In Europe our 220\230v supply is ample to drive even the most power hungry kit without any sag.
I worked on diagnostic machines for hospital haematology labs .. massive very expensive machines each with main conditioning units , the saturable reactors used to stabilise the voltage was standard for US labs and also fitted on the European models ..but unnecessary. I understand they were needed the other side of the pond.
If your house is next door to a small machine shop using arc welders, and electrical fly presses ..then yes,otherwise NO.
MaryWhitehouse
dannnielll
Aye...
..Thems fighting words!!!. No I like the French system, .. and have rewired a house (in France ) with their standards. Give me a good spur network and plenty of circuit breakers to a ring main anytime.
paulguk
The mains supplied is good in the uk as has been pointed out. What isn’t good is the local pollution such as neighbours wi fi and my own wi fi and other localised electrical devices that pollutes it. I‘m not imagining the differences in sound at different times of the day which is why I posted my question It is well documented that these things have an effect on the mains and it is also well documented that passive mains conditioning and or balanced mains also can help reduce these effects.
Hixs
MaryWhitehouse
You definitely are. Any change you’re hearing is not due to your mains. It may be down to other environmental factors but it’s not your mains.
By whom?
oscroft
Some time ago I definitely found a benefit from using a Tacima mains strip - it noticeably clarified and focused things. But I'm sure it's nothing to do with any problems with the domestic mains itself. I have a lot of equipment using switched mode power supplies in my room, including a bunch of electrically noisy computer gear, so I suspected all that stuff was putting noise back into the room ring.
Now, saying that, at the time I also had some audio gear using switched mode wall warts plugged into the same strip as my amps, TT, etc. Since then, in the course of my upgrades, I've replaced those warts with linear supplies (or replaced components that used them with ones that don't), and I recently did a new comparison between the Tacima strip and a plain everyday strip - and I can hear no difference now. I think that lends support to my speculation that noisy switched mode PS warts were my problem, though probably only the ones in very close proximity on the same mains strip.
I'm still using the Tacima mains strip, just because I like having surge protection - but I really can't hear any difference with or without it now.
I've also made up my own mains cables with thick shielded Belden cable and decent quality plugs at both ends. I can't tell any difference between them and standard (and more conveniently flexible) mains leads. Still, it was a cheap enough exercise making them myself, and it at least answered the question.
I am convinced that the quality of power supplies used in components is extremely important, and it pains me to see otherwise good gear powered by nasty cheap warts. But I'm firmly convinced that the quality of the mains (at least in the UK) is really of no concern.
Hixs
[QUOTE="MaryWhitehouse, post: 28496356, member: 794220"
By whom?
[/QUOTE]
The people who sell conditioners... :rotfl:
MaryWhitehouse
I’ve often wondered why linear supplies are often a very expensive replacement when my £170 phono stage has one as standard.
Paul7777x
If you absolutely must buy a mains device then this is the only one I’m aware of that actually does something real.
That is, it is a mains regenerator.
Passive components are at best a crock of sh*t. But they’ll empty your pockets which is their only purpose.
D
Mains induced noise from cheap Chinese wall warts are a wholly different thing. Again they don’t demand a grands worth of ‘magic boxes’ they just need replacing.
if you really want to decouple you’re HiFi from the mains, use an Online Double Conversion UPS as it will totally decouple it’s output power from its input.
https://www.criticalpowersupplies.co.uk/9px1000irt2u-warranty-+
oscroft
Yes, they can be amazingly expensive - I suspect it's partly due to low volumes, as aftermarket power supply demand is pretty specialised. But I've got a couple from Chinese suppliers that were more reasonably priced. I opened* them and checked them before use, and they appear to be well constructed with decent components, and properly earthed and all that. (*I thought voiding the Chinese warranty was probably not much of a sacrifice.)
dannnielll
This is going to sound contradictory...in light of my post #12 above.. i have a property in a quiet rural location in France, it is on the outskirts of a village town . 45 metres from me is a small substation transformer. And what was a small factory clothing at one stage. The transformer is silent by day but distinctly audible at night. I have an Sony DE400 AVR in my attic, and there is a distinct hum from its electronics, on FM radio but only at night. Not when doing CDs ,just radio.
I expect that the supply voltage is higher at night,as demand is greatly reduced. ..
Hixs
Maybe we're neighbors :D whereabouts? (roughly - no stalker honest gov!)
dannnielll
Hixs
Ah...other end of the country from me. I'm in 65.
Latest News
Focal launches Bathys noise-cancelling wireless headphones
  • By Ian Collen
  • Published
Formovie Theater UST projector hits the UK
  • By Ian Collen
  • Published
Sonus faber unveils new flagship Arena speaker series
  • By Ian Collen
  • Published
Sharp showcases its upcoming 4K TV and audio line-up
  • By Ian Collen
  • Published
HiFi Rose announces all-in-one RS520 audio streamer
  • By Ian Collen
  • Published
