After a Component Splitter..
Discussion in 'Cables & Switches' started by CrossyX, May 4, 2005.
  1. CrossyX
    CrossyX
    Feb 15, 2005
    2,979
    3
    83
    +207
    After a 2 or 3 way component splitter but strugglin to find one. Any ideas? (decentish one)
    Thanks Crossy
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    CrossyX
    Is it 'one to many' or 'one to one' with selectable output?
    YUV Only or YUV + Audio?
    Two outputs or Three - it makes quite a difference to your 'possibilities' list?
    Best regards
    Joe
  3. CrossyX
    CrossyX
    Feb 15, 2005
    2,979
    3
    83
    +207
    Sorry yeah selectable output. YUV only . For xbox and dvd player. Wasnt sure to get a 3 way just for future use (maybe) but at the min 2 way would doe (selectable)
    Thanks Crossy
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,763
    The Borders
    +3,088
    Hello CrossyX
    I'll start from the top as its easy to mix up terminology.
    01. Inputs - How many YUV sources?
    02. Outputs - How many YUV Displays?
    03. Outputs - If multiple Outputs are required can it be One selectable Output active at any one time or all Outputs to be active (all showing the same source)?
    Best regards
    Joe
