Affordable RCA component to HD15 VGA cable?
Discussion in 'Cables & Switches' started by norm, Jun 2, 2005.
  1. norm
    norm
    Feb 2, 2005
    349
    Devon
    +7
    Panasonic projector, takes component picture on the VGA in port but I need an adapter cable. Any recommendations on what and where to buy?
    The manual mentions a BNC RCA adapter cable type thing (but shows a picture using only 3 of the 5 plugs.
    [​IMG]
    Would the above work however?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,729
    The Borders
    +3,079
    Hello Norm
    A 3RCA to HD15 cable will work if your Projectors HD15 (VGA) Input is YUV compatible.
    These cables tend not to be in the budget category - we have some high quality BetterCables Silver Serpent on Special Offer to AVForum members in the Cable Power Buy section; see http://www.avforums.com/forums/showthread.php?t=185776
    Best regards
    Joe
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    There are some 'budget' DB15/YUV cables Here and are available with either RCA or BNC connections.
    Mark.
  4. norm
    norm
    Feb 2, 2005
    349
    Devon
    +7
    Thanks for the replies.
    The projector in question doesn't mention "YUV" support in the manual but it does mention YPbPr?
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,729
    The Borders
    +3,079
