Affordable DVD player with Progressive Scan
Discussion in 'Blu-ray & DVD Players & Recorders' started by Waser, Jul 1, 2004.
  1. Waser
    Waser
    Mar 1, 2004
    983
    Purley, Surrey
    +57
    Hi all, little bit of advice needed. I was originally in two minds about whether to go the all-in-one or seperates route. I have settled on seperates and I am looking to get a hold of a progressive scan capable DVD player with component out to start building my system. Budget is around £150. Are there any affordable progressive scan players with NTSC and PAL compatibility at this price range? I have heard that the cheaper players can struggle with progressive scan. Any suggestions or comments are welcome?
    I know the Cambridge DVD55 is an option. How about the Tosh SD530 (£125 Multi-Reg from Richer Sounds)? Is the Tosh NTSC and PAL progressive?
    http://www.richersounds.co.uk/index.php?f=itemdetl.php&p=301687
    I would love a Jamo DVR50 but they are a bit pricey.
  2. boab_is
    boab_is
    all the new pioneer DVDs are pal progressive, even the entry dv370, probably get that for pennies online
  3. Waser
    Waser
    Mar 1, 2004
    983
    Purley, Surrey
    +57
    How do pioneer players work with Panasonic TVs? I heard there was an issue with this combo, am I right?
    Are they much better than the Tosh I mentioned?
  4. Andy_t
    Andy_t
    Jun 29, 2004
    69
    The new Toshiba sd340 has PAL Progressive Scan. You can get that for around £90.
  5. Waser
    Waser
    Mar 1, 2004
    983
    Purley, Surrey
    +57
  6. Waser
    Waser
    Mar 1, 2004
    983
    Purley, Surrey
    +57
    I just found that pioneer is NTSC prog scan only... Any others worth considering?
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    10,793
    2
    +3,150
    565 is NTSC PS only. The new 575 does PAL and NTSC prog scan and is available from about £150.
  8. Waser
    Waser
    Mar 1, 2004
    983
    Purley, Surrey
    +57
    I like the look of the Pioneer 470. I don't really need the SACD and DVD Audio that the 575 provides.
    At the moment I am erring towards the Pioneer 470 over the Tosh sd340 as the Pioneer is PAL and NTSC prog scan.
    It's not out yet though, which is a bummer.
  9. Dutch
    Dutch
    Dec 5, 2002
    2,562
    3
    North Yorkshire
    +257
    Waser,
    I think that if the Toshiba 340 does PAL PS, you can expect it to do NTSC PS also.
    Steve
  10. Waser
    Waser
    Mar 1, 2004
    983
    Purley, Surrey
    +57
    Steve,
    My understanding is that it doesn't...
    But I'm probably wrong... :)
  11. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    Toshiba SD-340 does do pal ps.
    Wasabi
