Affect of speakers on TV?
Discussion in 'General TV Discussions Forum' started by Daneel, Jan 22, 2005.
  1. Daneel
    Daneel
    Dec 5, 2002
    2,843
    68
    London
    +8
    I'm considering buying a tv from a forum member in classifieds but I'm concerned that my front speakers will be too close to it and cause problems, see this thread.
    There will only be 25cm between the sides of the tv and my JM Lab Electra 926 speakers. Are they likely to distort the picture or otherwise interfere with the TV?
    Thanks for your help.
  2. Chris Hedlund
    Chris Hedlund
    Those look pretty powerful speakers. If they are not screened internally for home cinema then 25cm is too close.
    Cheers Chris
