aerials
Discussion in 'General TV Discussions Forum' started by nalabro, Nov 15, 2001.
  1. nalabro
    nalabro
    excuse my stupidity but i have an aerial boosted aerial which will
    not give an adequate picture on all channels simultaneously.
    would an outside one work? any other suggstions?
    cheers
  2. UlricVonLichtenstien
    As ITV will be available on Sky as of next week (See posts in the Satellite forum and on Digital Spy, get yourself a dish and all your picture problems will be a thing of the past! ;)
  3. swhits
    swhits
    Oct 23, 2001
    103
    Sheffield
    you don't state whether your aerial is mounted outside on the roof. Assuming it is, you could do with getting hold of a spectrum analyser which will tell you the signal strengths of the channels you receive. You should really be looking for signal strengths of between 45 & 80 dbs on each channel. there are so many variables that it may pay you to get an aerial specialist to upgrade your system. (a high gain aerial and possibly a masthead amp may solve your problems) You could be looking at anything between£75 and £150. It'll pay to ring round but ask if they will be able to provide you with before & signal readings to see the improvements.:cool:
  4. nalabro
    nalabro
    good point and thanks. it's an internal boasted aerial.
