Aerial
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Jafferolli, Aug 6, 2005.
  1. Jafferolli
    Jafferolli
    Jul 30, 2005
    25
    Does anyone know if a different aerial would improove the quality of picture on a sagem freeview box ? I live in a area with a very strong signal. :confused:
  2. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    The quality of the picture is down to the freeview box, if the signal is breaking up then a new aerial may help.
  3. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
    In a strong signal area it is most important to use good quality double-screened coaxial cable - otherwise the cable acts as an aerial and causes picture problems.
    You might also suffer from reflected signals which, on analogue, causes ghosting. The effect is not obvious with digital but it can cause "dropout". An "anti-ghost" aerial with fairly low gain might be useful.
