Aerial Switch for old games consoles
Discussion in 'Cables & Switches' started by grismtrax, Dec 19, 2006.
  1. grismtrax
    grismtrax
    Aug 13, 2005
    125
    +3
    hi,
    i have a number of old gaming consoles (nes, snes, megadrive, master system + others!!) that connect through a normal aerial connection on the tv. I have a bunch of switches (2 to 1) daisy chained together so that i can switch between the consoles without having to unplug any wires for whichever console i want to use. I wondered if there was any type of switch box that would allow me to replace all of these individual switches? It really is a mess!! I have had a search but not found anything yet so any help would be appreciated.
    Thanks.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    I have only seen expensive 4 to 1 coaxial switches sold by PC and networking suppliers; these cost about £100 and use BNC connectors - so adaptors would be required to standard TV-type IEC (AKA Belling Lee).
    Chris Muriel, Manchester
  3. djt111
    djt111
    Nov 29, 2006
    1,464
    63
    +203
    make 1 of these up
    you will still have to connect whitch consol you want to play, but will look better!
    [​IMG]
    1 wire going to the back of your TV the others going to the consols and 1 to the arial?
    http://www.satcure.co.uk/tech/fconn.htm
  4. grismtrax
    grismtrax
    Aug 13, 2005
    125
    +3
    thanks for both your replies, think i will have a go at making one looks like a nice cheap neat solution.
    thanks again.
