Aerial split signal question
RAINS
I have currenty moved into a house whereby the orignal owners have split the single coax cable from the aerial into two feeds using a plastic splitter.
The signal to the TV in the bedroom is not great.
Rather that running a new lead can i unplug the main feed from the splitter and connect to the one to the bedroom only? Will this improve the picture as the cable has been cut?
I don't need one for the living room as i have Telewest.
Thanks chaps / chapettes :smashin:
Chris Muriel
Yes, that should give you about double the signal to the bedroom. You just need a male-to-male barrel connector.
Chris Muriel, Manchester
RAINS
Chris, thanks for the response. I think the splitter has 1 male and two female connections therefore i should be able to connect the two ends together.
I bet they are the same diameter..... dame i better go to maplins just in case.
:eek:
Podcast: TCL C815 TV, Denon & Huawei wireless speaker reviews, New Sony 4K PJ's and more
