Aerial socket on PV500
Discussion in 'Plasma TVs Forum' started by SonOfSony, Jun 20, 2005.
  1. SonOfSony
    SonOfSony
    Hi, sorry if this sounds a remarkably stupid question, but I am having a digital aerial fitted next week in readiness for the arrival of my PV500. How would the connection fit to the PV500? Is there an aerial socket on it and is that what is used for the digital aerial connection to view Freeview channels?
  2. SonOfSony
    SonOfSony
  3. av2diefor
    av2diefor
    Is it April 1st :eek:
  4. ikon66
    ikon66
    Mar 22, 2005
    444
    Tyne & Wear
    +5
    Not sure about the panny but my xde has 2 sockets one for freeview and one analogue, maybe they are hidden elswhere :rtfm: only jokin
  5. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Goes in just above the component connection, one aerial socket, normal type for freeview and analogue
  6. Enquirer
    Enquirer
    Coax tv connection
    [​IMG]
    Plug
    [​IMG]
    Socket
    See diagram below for exploded view of a plug connector.
    1: Unscrew the two parts of the plug and slide the cover (the back part) onto the cable.
    2: Twist together the screening and wrap it around the outer insulation. Place the brass 'claws' over the centre conductor, covering the screen.
    3: Strip away half the inner insulation to expose the inner conductor. Check that the inner conductor is not touching the screening.
    4: Push the centre conductor into the hole in the front half of the plug as far a possible. The centre conductor should show trough the hole from outside, and the brass claws should trap the screen, with the outer insulation underneath. Screw the two halves of the plug together, this will squeeze the brass claws tight on the cable insulation to grip the cable.
    5: Cut off the excess wire showing through the centre stem of the plug. To give a really good contact the centre wire should be soldered.
    [​IMG]
    the plug goes in here
    [​IMG]
  7. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,613
    London
    +468
    Now that's what I call an informative answer !
    Supoib Enquirer :thumbsup:
  8. SonOfSony
    SonOfSony
    Mal - surely you must be deserving of some kind of award for the most detailed answer ever posted on the forum? :D
  9. av2diefor
    av2diefor
    Sonof you also deserve one :D
  10. SonOfSony
    SonOfSony
    Lay off! You might have guessed I'm not knowledgeable about such matters! Anyway, what part of it that was so unbelievable?!
  11. av2diefor
    av2diefor
    Chill :cool:
    Only shedding a bit of light entertainment.
    You have to admit though asking where the aerial connects to a tv is a strange post for someone that has the intelligence to buy great plasma :smashin:
  12. SonOfSony
    SonOfSony
    I think you misunderstood me. Of course I know where and how an aerial connects, but the link I put in my original post shows the back of the PV500 and I couldn't see the aerial in socket anywhere. Just wanted to check it was there before shelling out £180 to get a digital aerial set up!
    I was chilled! :cool:
  13. av2diefor
    av2diefor
    Well it looks like the Equirer was kind enough to answer your question.
    The End :boring:
  14. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,613
    London
    +468
    Guys lets Chill....otherwise rather than The Enquirer to answer your question we'll get The Punisher to do it...and he'll probably just tell you where to stick it (aerial of course) ! :D
  15. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    I hate to spoil your guys fun but.. the Aerial is fitted to a socket that is facing downwards, hence you can't see the aerial socket in any pictures. It is on the right hand side.
    :D
  16. jedimaster1971
    jedimaster1971
    May 28, 2005
    52
    :eek: wowser I gotto put my prices up.... I only charge £70 quid for a digital aerial install, less if the cable run aint that long?!?!?!?!?!?
    what kinda aerial you fitting? for £180 quid I will come and put your aerials up all day long
    Jedi
  17. SonOfSony
    SonOfSony
    Jedi - a digital aerial. However we live in an area where technically there is no Freeview but 'booster' power boxes are used and a very good signal can be dragged in so we need one of those. The price also includes to four different points within the house and all wiring obviously plus dismantelling of existing aerial and cabling.
    Thought £180 seemed reasonable enough?
  18. jedimaster1971
    jedimaster1971
    May 28, 2005
    52
    sorry mate i just thought it were gonna be 1 A/E to one point, as you described the low sig area, larger aerial req of bat, then a booster add £80-100 and to four rooms maybe another £ 70-120 quid total approx £280-£300 before any discount so yes £180 is a very very very fair price mate
    My fault for leaping without getting all the details
    jedi proceeds to put brain into gear before opening mouth
    ha ha ha ha
    Jedi
  19. SonOfSony
    SonOfSony
    Your price guesses are spot on. It would normally cost me about £250 but I managed to knock him down to £180! He's agreed to keep the price open to me for a month while I wait for the TV to be delivered - I'll then call him in and see what he can do. He's promised to charge me nothing if he can't get a picture I'm happy with - although I would imagine that's standard procedure.
  20. jedimaster1971
    jedimaster1971
    May 28, 2005
    52
    not really guessess mate its the average market price.... I been digital fitting and sky fitting for over 10 years now so prices can vary......
    pm for trade secret prices mate
    jedi
