Aerial/RF Cable query?
Discussion in 'Cables & Switches' started by 9761, Jun 1, 2005.
  1. 9761
    9761
    May 16, 2005
    536
    Im going to put my main aerial cable into my Freeview box, my freeview box has RF loop so the RF out will then go into my TV but my question is the cable you get free with the box or TV thats like the aerial can you use something like WF100/CT100 cable with connectors on the ends to give better results?
    Thanks :lease:
  2. loadsofleads
    loadsofleads
    Hi, you can use CT100 cable to do that but the results would be no better. Don't forget if you feed the ariel into your STB and then a rf cable into your tv you will only get the basic composite picture. Your better off using a good scart cable from your STB into your tv for RGB video.
    :hiya:
  3. 9761
    9761
    May 16, 2005
    536
    Well I am going to connect the STB to the TV via RGB scart but the main aerial will go into my STB and a RF Cable from the STB into my TV.
    So I can get some analog.
    So would I better of using the standard one which comes with the TV or over stuff or buy a good one from somewhere?
