Kentdougal
- Joined
- Apr 18, 2012
- Messages
- 3
- Reaction score
- 0
- Points
- 1
I have 4 TV's distributed around the house with single aerials carrying analogue & Sky from a splitter that works perfectly. The main TV has built in Freeview which also works fine.Now a number of questions
1)It would seem possible to me that I should also be able to receive Freeview on the other 3 TV's from the same system although I don't seem to be able to achieve it.I realise the same Sky program or Freeview program would be on all TV's as it does now as I don't have multi room.Is this possible
2)I bought a scarp TV capture to use on one TV instead (using the same aerial arrangement)It didn't work showing no signal.Phoned the suppliers they said it wasn't compatible with Sky(although not mentioned in the adverts)Is there any way of separating the satellite and terrestial(will be Freeview)signals but still use the same aerial.
Finally I am not yet switched over to digital due in June.
Any help gratefully received
Kentdougal
Kentdougal
