Aerial problem
Bess
I've moved into a house but just can't work out how the aerial works. There is an aerial socket and coming out of the wall is an aerial and another aerial comes out of the side of the aerial socket.
There is a remotelink a120d booster with 'input' and 'out 1' and 'out 2' and a white triangle with 2 aerial connections on one side and one on the other side.
There is another aerial in another room so I guess there must be a link to that here somewhere.
Help would be very much appreciated- I've tried lots of different combinations to no avail! Thanks
Over by there
Perhaps a silly question but is there an aerial and cable leading into the house?
My preferred method is connect a TV directly to the feed coming direct from the aerial to prove that working first before getting involved with amplifiers or splitters etc. The aerial looks like the other house aerials and roughly pointing the same way?
Is there a plate you can remove to make sure there is something connected the other side?
Bess
Thank you so much for your response. There is a cable leading into the house and I did as you suggested and the TV worked. I did a lot of research and eventually understood what the various connectors etc did and I have just managed to make the TV work! Thank you very much again for your response
Danny99903
Hi I’m having trouble getting a good freeview picture with my Sony tv the signal strength is up and down and the picture goes blurry every now and again, the coax cable goes from my tv to a sky dish. How can I improve it?
JayCee
Freeview is Terrestrial digital TV here in the UK fed from an aerial with a coax plug into the aerial input on your TV.
If your TV is fed from a satellite dish and the coax cable downlead has an F-Plug screwed into the Satellite input on your TV that's Freesat.
Which is it?
Danny99903
Which is it?
Ok I’m not sure but my tv has a TV guide setup on it which I use and it’s fed in with coax cable from sky tv sattilitte dish?
