aerial problem short circuited
Discussion in 'Plasma TVs Forum' started by a5ian300zx, Oct 23, 2005.
  1. a5ian300zx
    a5ian300zx
    Jun 14, 2005
    3,631
    2
    North London
    +445
    I recently bought a Pioneer 436XdE-TA plasma, i tested it out.
    DVD spot on breathtaking.
    freeview - theres a problem it keep saying short circuited on the plasma and advises me to remove power and reconnect. This is due to not having a stong aerial (i think) its connected to a new aerial on the roof, and my room is the loft room. (also the picture is not all that on analogue ad digital)
    o.k. i have bought the following SLX 2 signal booster.
    will this fix my problem or is there anything else i could do?
  2. nickeddle
    nickeddle
    Feb 2, 2005
    352
    North Yorks Moors National Park
    +10
    The problem with "the short circuit" message is easy to sort out,go into Home Menue,Auto Insallation, then turn to Off Aerial Power.
    Regards,
    Nick
  3. a5ian300zx
    a5ian300zx
    Jun 14, 2005
    3,631
    2
    North London
    +445
    Thanks mate will give it a try.
  4. Fatdankfc
    Fatdankfc
    Sep 19, 2009
    Uk
    Hi, I've had the same error message today, did you get it sorted out?
  5. stuart2
    stuart2
    Feb 24, 2006
    335
    +14
    I've had that error message since I bought my 436SXE in May 2006. I just adjust the volume control and the message goes. It's not a problem.
    I might try nick's method though to avoid the message popping up all the time.
