Aerial Problem Please Help
Discussion in 'Satellite TV, Sky TV & FreeSat' started by deerboy, Feb 24, 2005.
  1. deerboy
    deerboy
    can anyone please advise me on a problem with a freeview box please? I can't get any reception although the channels are there. the words BAD SIGNAL appear and nothing happens. Can i boost my aeriel signal somehow?
    It's Thomson box (bought on ebay) and is quite basic. I apparently live an area that is freeview receptive. Can anyone help me please?
  2. Dillz
    Dillz
    Feb 25, 2004
    236
    Gloucestershire
    +8
    Have you just bought it on Ebay, received it and plugged it in? If so you will just need to a channel search. This is because the channels stored on there already will be stored to the transmitter of the previous owner and they are most likely different to the transmitter your TV comes from.
    I am not familiar with the menu on your receiver but there will be a "setting up" option or similar where you can search for all the channels.
  3. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Also, make sure you have a wide band width ariel and that its pointing in the right direction :thumbsup:
  4. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
  5. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
    Is there any particular type of amplifier required for Freeview, or will any old amplifier do?
  6. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    Most amplifiers are fine, but make sure the gain is over 10dB.
  7. vizslaraner
    vizslaraner
    Dec 13, 2003
    487
    Hereford
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,591
    Rainham Essex
    +2,543
    For Freeview you should use a 'masthead amp' that is placed on the aerial. A standard booster that goes near the TV etc will just amplify any noise and interference that is picked up along with the TV signal and therefore often wont help with DTT reception.
    Mark.
  9. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
