Hawki007
Hi all!
I'm about to upgrade my radio fm and dab from non existant to hopefully useful!
I want to ensure that the TV signal does not drop out, we get loss of signals usually in the summer due to interference!
However, we have a powered masthead amp, connected to an antiference a240 amplifier in the loft.
What I want to do is add seperate dab and fm aerials, omnidirectional fm and a linear dab aerial.
I will have three cables coming into the loft, the amp has a combined fm/dab input and a seperate TV input.
My plan is to get a duplexer to combine fm and dab onto one cable before being fed into the loft amplifier.
Is this correct?
What other considerations do I need? The loft amplifier has variable gain controls on it... Will I need to alter these?
Also, there is an output called 'full' rather than TV 1,2, 3 etc. Is this the one to use as it will send all signals down the cable?
Sorry for all the questions but I have tried to find out as much as possible in advance!
Is this correct?
