aerial flylead
davepuma
I'm after a good quality 3-4m aerial flylead that is cheap and white. There are plenty of cheap and nasty stuff out there. I have one that I got from Argos and the fit is terrible. I've seen IXOS etc but they're too dear. The only cheap(ish) brand name ones are Profigold but they're black. Has anyone bought a ready made flylead that they could recommend. Alternatively does anyone know of anywhere that would make a length of co-ax up or where I could buy a 3-4 metre length and do it myself. I don't want to buy a drum of the stuff!
SlinkDaddy
Any indie worth their salt will sell decent coax by the metre and if you ask them nicely will probably terminate the ends properly with solder for a small charge. If not maplins or even a big b&q.
davepuma
Cheers for reply. I will probably end up making up a lead myself but thought I would get a ready made one preferably in white that didn't cost the earth.
