Aerial Extension Problems!
Discussion in 'Cables & Switches' started by dustroom, Sep 12, 2005.
  1. dustroom
    dustroom
    I am trying to take the signal from my external roof mounted aerial - which runs straight into the TV downstairs in my lounge - and extend it's use into 2 upstairs bedrooms.
    I have no idea where to start! What junction boxes to use, whether I need a distribution amplifier, what cable to use, what sockets to use etc. Also I don't know whether I should put some kind of splitter downstairs running into the TV then one cable running upstairs, then put another splitter upstairs to divide into the two rooms.
    I'm capable at wiring, and I recognise the cables and what should go where but i have no idea what any of them are called!
    Any "idiots guide" style help would be fantastic!
    Please help!
    Dave
  2. paulflowe
    paulflowe
    http://www.satelliteonline.co.uk/f_type_splitters.htm
    or if you have a power socket in the loft go for
    http://www.satelliteonline.co.uk/amplifiers.htm
    Connect your roof aerial to the input, then run good coax (don't want signal loss by using poor cable) to the points in the bedrooms, terminating on a wall port or for a semi-perm solution fit a grommet over the holes in the wall.
    The best solution is a 2.4GHz wireless transmitter, connected to the aeriel, then receivers in each room - but these aren't cheap.
    Anyway, the above should get you towards where you want to go. The rest of the aforementioned website is a good read, by the way.
    Paul. :clap:
  3. guli
    guli
    Sep 3, 2004
    412
    16
    Paul,
    Any recommendation on a good 2.4GHz transmitter for tv signals?
    Alex
