Not sure if this is the right section to post so apologies if it is but hopefully someone can help me out.
I just bought a new lcd with built in freeview for the bedroom. Bought a more expensive digital aerial thinking I would need it, but it is useless.
So I plugged in the aerial off my old tv which is basically like a coat hanger, and it works fine. However the problem is this, I also have a freeview pvr box that I want to keep using because now and again I need to record. But the position the aerial has to be in to get the freeview signal it wont reach the pvr.
Is there some kind of extension cable I can plug the aerial into which then plugs into the pvr?
Thanks.
Thanks.
