Currently have a philex high gain wide band (27884D) in the attic but i in tend to put it on the end of the house to get it out of the attic, but not sure if this is the best aerial for me as wolfbane seems to suggest group E high gain. The picture just now is not that great but could be down to the mish mash of coax in the attic. Right to the point.
1 should i put this aerial up as i have it and see how it goes or bin it for a specific group E and if so which one.
2 I am re running all the coax using webro wf100 as i have 100m drum of it. Thought i read somewhere you should have all the runs the same length, due to something that escapes me just now, but that would use alot of cable. Is the cable ok and have you heard of this keeping the runs the same length.
3 i want to send the signal to up to 6 outlets but only 3 will be used initially. Can you recommend an attic distribution box and do you need to put anything in the outlets that are not connected to a tv. I will put a 240v supply in the attic for the box.
4 where can i find and what diameter pole should i be getting.
5 am i missing anything.
6 cheers for any help you can give
gear and info i have so far, you can see when i used post code and co-ordinates the wolfbane info changed.
http://www.philex.com/parts/show/27884D
