aerial connector on mustek dtv 408 pro
Discussion in 'Video Streaming Boxes & Services' started by armarni, Mar 19, 2005.
  1. armarni
    armarni
    Mar 19, 2005
    28
    3
    +8
    Hi everyone
    Anybody know where to get an adaptor to plug an ordinary rf aerial into this player? The socket for the supplied aerial seems to be totally non standard...not mini uhf, not mini jack. The supplied aerial can pick up a strong signal, but i need a better aerial to pick up freeview at home. Any info on what the connector is would be greatly appreciated as mustek technical support arent replying to emails on the subject.
  2. roym
    roym
    Sep 13, 2002
    87
    +3
    i had the same problem as you, i emailed mustek and got this reply
    Dear Customer,
    up to now there is no Adapter available.
    You must build a Adapter by your self.
    Adapter 730349-14 to kabel 280356-13 by www.conrad.de
    Best regards
    Mustek Support
    so in the end i had to cut the supplied ariel lead in half and re connect it with a male and female RF connector. now i can connect my house ariel and a small portable booster for when i am out and about. by the way am very impressed with the dtv 408.
  3. armarni
    armarni
    Mar 19, 2005
    28
    3
    +8
    thanks for your help roym
    looks like I'll have to bite the bullet and do some diy myself. Seems so strange that they supply all manner of leads with the player which i could easily buy at maplins if i wanted them, but the one adaptor which is totally non standard they fail to give you! I too am very impressed with the 408 as well.
  4. carl1010_1
    carl1010_1
    Apr 19, 2005
    201
    +4
    i took delivery of the mustek dtv 407 today and am not getting the best reception and am looking at a modifying it..
    not being the sharpest knife in the draw :confused:
    how do i go about doing this modification to allow me to use a booster .
    i presume the rf connectors are just normal coax(telly)plugs??
    :lease: :lease: :lease: help me
  5. armarni
    armarni
    Mar 19, 2005
    28
    3
    +8
    using the info from roym i ordered the connector from the german website. They want u to order 50 euros worth of stuff to make shipping worthwhile, otherwise its £15 to ship a 50p widget! It took about 10 days to arrive, then just soldered it to one end of a standard aerial extension lead et voila. If ur not too handy with a soldering iron I'm sure a local electrical shop will do it for a small fee
  6. Jumbocruiser
    Jumbocruiser
    Received the following email from Mustek today:
    Dear Customer,
    up to now there isn´t a Adapter. We wait also for this. It will
    deliver in a few weeks.
    Best regards
    Mustek Support
  7. picklesdavid
    picklesdavid
    I called Mustek today (06/07/05) on 0870 0132017 and they are sending me an adaptor so that I can use a standard aerial. Its costing £10.50 ish inc. p and p.
    Hope it turns up!
  8. eladHubbuck
    eladHubbuck
    I would be gratefull if you could post how you get on with the adapter.
    I'm thinking of purchasing one of these but only if i can connect to to my house's tv distribution cabling.
    thanks
  9. Hywel
    Hywel
    I've just called Mustek on 0870 0132017. They are sending me an adaptor so that I can use a standard aerial.
    Its cost £7.99 inc. p&p.
    You can pay by credit or debit card.
    They have some in stock at the moment. :thumbsup:
  10. Stevie1
    Stevie1
