Aerial cable testing
Discussion in 'Freeview & YouView' started by r055bud, Jan 8, 2012.
  1. r055bud
    r055bud
    Jan 8, 2012
    10
    Is there any way to test my aerial cable to determine which room they go to?
    I have 4 cables in loft going to 4 rooms in the house but unsure which is which.
  2. winston2010
    winston2010
    Jun 28, 2010
    1,872
    London
    +172
    Depends what equipment you have.
    Put a battery across each one in turn in the loft and go round the other ends with a multimeter.
    Or, possibly connect each one in turn to an aerial and check the picture on a portable TV in each room. Easier if you still have analogue.
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    It sounds as if you're going to connect these cables to a 4 outlet distribution amplifier.
    If so, does it actually matter which is which, as long as they all work! :)
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,009
    +6,864
    If you have a meter or any kind of continuity tester, you can test all four to ensure they are open circuit to start with ... then add a shorting plug to each outlet in turn and test again to identify which cable belongs to that outlet.
  5. r055bud
    r055bud
    Jan 8, 2012
    10
    Thanks for your comments. I have been in the loft and traced all the cables.
