aerial cable short circuited
Discussion in 'Blu-ray & DVD Players & Recorders' started by Miraage, Jan 19, 2005.
  1. Miraage
    Miraage
    Jan 14, 2005
    7
    Everything seems to be working on my system:
    Pioneer PDP435XDE 42" plasma
    Panasonic E95
    Sky +
    However, a message keeps appearing on the screen:
    "The aerial cable has short circuited. Check cable and plug in again."
    If I press the menu button on and off, it disappears, but it appears next time I turn the units on.
    Any ideas please?
    Thanks,
    Shirley
  2. JayCee
    JayCee
    Jan 20, 2004
    21,767
    Lanarkshire
    +2,236
    Are you getting a normal pic and sound?
    Which "Menu" button are you talking about....Pioneer, Panasonic or Sky+?
  3. Miraage
    Miraage
    Jan 14, 2005
    7
    I am getting a normal picture and sound, that's why it is weird !
    The message is coming from the Pioneer PDP435XDE 42" plasma system.
    It has been there from the beginning but once it goes away everything still works normally.
    Thanks,
    Shirley
  4. eddyad
    eddyad
    Jan 5, 2003
    940
    Hampshire
    +9
    Have you checked the cable? Maybe a stray strand from the screen is touching the central conductor inside a co-ax connector.
    If you have an external aerial connected to the TV there could be water in the junction box at the aerial (especially if it's an old installation), and I hate to sound depressing, but water running down inside a downlead isn't unknown.
    You may be able to isolate it in stages. If the downlead ends in a wall socket, unplug the co-ax. Thre won't be a signal, but a short in the cable connected to the TV may be detected.
  5. JayCee
    JayCee
    Jan 20, 2004
    21,767
    Lanarkshire
    +2,236
    If the aerial is plugged into the Sky+ or DVDR unplug it and plug it in to the Pioneer directly and see if you still get the message.
  6. WRIGHTY1966
    WRIGHTY1966
    Feb 15, 2009
    9
    I have the same problem and i did notice water in the down lead...thing is does this mean i have to replace the aerial cable ...or does it mean i have actually damaged the t.v ?
  7. WRIGHTY1966
    WRIGHTY1966
    Feb 15, 2009
    9
    Hello Shirley
    Did you manage to sort the problem out..and could you please tell me what you did
    cheers Steve :)
  8. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,733
    +6,425
    Welcome to the forum.
    Yes The downlead requires replacement.
    Whether damage has occurred will depend on which piece of equipment the downlead was connected and how much water may have seeped in or for how long.
  9. WRIGHTY1966
    WRIGHTY1966
    Feb 15, 2009
    9
    Cheers gav for the reply
    the lead was in about a minute lol...
    i took it out straight away and noticed water coming from it...:(
    i thought just my luck,,,
    thing is it's a very expensive kuro t.v 50"
    so you can imagine my horror when the warning note came on
    i'm hoping all i need to do is replace the aerial lead and all will be ok...
    Steve
  10. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    20,733
    +6,425
    You should be ok.
    Disconnect TV from mains and ensure everything is as dried out as possible.
    Tissues - Hair drier - NOT on a hot setting though. Cool or gentle warmth at most.
  11. WRIGHTY1966
    WRIGHTY1966
    Feb 15, 2009
    9
    :smashin:thats made me feel a little bit better :smashin:
    cheers pal :hiya:
    Steve :clap:
