Aerial Cable Routing.
Discussion in 'Digital TV & Video Players & Recorders' started by Skiddins, Jul 21, 2004.
Tags:
  1. Skiddins
    Skiddins
    Feb 4, 2002
    102
    16
    Windsor, Berkshire, UK
    We have an aerial which is about to be mounted on the chimney stack.
    It will have a cable running down the outside of the house to supply a signal to an upstairs room then down to a room directly below.
    We planned to route the cable down to the first room, in through the outside wall, to a wall mounted socket, then have a cable running back out from this socket and downstairs where there will be a temporary outside connection (until the room is decorated shortly).
    Does this sound reasonable?
    Will I need a specialist booster in or beside the upstairs wallsocket to make sure there is no loss of signal?
    Any help appreciated.
    Skiddins
  2. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Depends how strong the signal is and what you want to do with it. A distribution amp is usually a good idea and should be the first port of call for the cable. Maybe this could be in the loft? If you have a weak signal and want freeview then you can get a masthead amplifier which fits up near the airial on the mast. You can then get a distirbution amp that will poser this amp through the coax cable. I have this and it works really well so I get 7 excellent signals sent around the house.
    It's a bit involved and of course will cost a bit but I decided to do the job properly in the first place. May I also suggest you use some good double shielded coax cable outside, especially if you live near a road or in town.
