littletreasure
I am planning on having my current aerial replaced and would like a bit of advice as I am totally clueless about the whole subject.
According to the Wolfbane site I am on the Winter Hill transmitter (20 miles away) and I need an amplified extra hi-gain aerial. I gather that WC100 is a decent type of cable to go for. I assume an aerial installer would know what to get? If I end up buying the stuff myself, what aerial would people suggest? It is going on the roof and not in the loft.
I have 2 televisions that I would like to connect to the aerial. Can you get aerials with 2 outputs or do I need a separate splitter? If I need a splitter, do I need to get one with a built in amplifier? Again, any suggestions of what to get would be great.
Thanks in advance.
Thanks in advance.
