Bobbydazzler74
Hi... This is my first post so apologies should this one find itself in the wrong sub-topic. However I was hoping to be able to tap into the expertise out there.
I have just erected a new rooftop aerial/antenna having taken advantage of my neighbours scaffolding. I purchased new cabling (CT100) and a proception masthead amplifier to boot as I'm in a poor reception area..
I also have an anterference 2 way splitter.
So my issue...
I have two TV's but signal to one TV only. The one which doesn't have signal hasn't had the cable replaced (RG6). Does this need to be CT100 as well?
The red light on the proception power supply lights up when the fly lead is about 2" away from the back of the telly indicating a fault but stays green if not connected. Would this be a problem with the fly lead?
I hope that makes sense and I hope someone can help me. Thanks
So my issue...
