Aelite 3 by Acoustic energy
Discussion in 'Home Cinema Speakers' started by norge, Apr 25, 2007.
  1. norge
    norge
    Apr 22, 2006
    379
    +8
    These speakers at the bottom end on the back there is a circular aperture......Should these be closed with the supplied plastic taps?
    Why they do not come closed with the supplied plastic taps from factory?
  2. scotty38
    scotty38
    Oct 28, 2004
    491
    +31
    I don't own, nor have ever seen the rear of these speakers, but I assume it's the bass reflex port which you could plug or not depending on taste and speaker location.
  3. Bossk128
    Bossk128
    Mar 15, 2006
    1,816
    2
    Perth
    +267
    Are the speakers heavy? My AE Aego speakers were mass loaded with kiln dried sand to keep them firmly fixed to the floor at high volumes. The bung was placed on afterwards. Perhaps your speakers have the same functionality?
    When I read the flippiin manual, it mentioned not to close the bungs over unless you were happy- they are designed to stay on after fixing!
  4. norge
    norge
    Apr 22, 2006
    379
    +8
    I would say, it is a bass setting.....but not sure, maybe someone owns a pair....
    Thanks the same
  5. Bossk128
    Bossk128
    Mar 15, 2006
    1,816
    2
    Perth
    +267
    I still think it's a space for filling with sand. :D
    What do the instructions say?
  6. norge
    norge
    Apr 22, 2006
    379
    +8
    Haha:D Filling speakers with sand!!!
    Well I might fill them with concrete for better grip!
  7. norge
    norge
    Apr 22, 2006
    379
    +8
    Confirmed....that opening is for mass loading
    You were right!!:thumbsup:
  8. tidytrev
    tidytrev
    Feb 15, 2007
    342
    +9
    they come sand filled already, i have some and mine were sand filled from the factory, disregard the manual
