Aego2 Owners - Advice please!!
Discussion in 'Home Cinema Speakers' started by chez, Jul 10, 2003.
  1. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    I have just ordered some Acoustic Energy Aego2's for my PC, which are being delivered tomorrow.
    My only question is what wires come supplied with it? I don't want to get the speakers tomorrow and not be able to use them straight away!!
    I know the inputs on the back are phono plugs, so I presume the lead that comes with it is a phono-phono lead rather than the 3.5mm plug-phono lead that I will need to connect it to a PC soundcard?
    Chez
  2. gaz.thomas
    gaz.thomas
    Dec 17, 2002
    62
    Worcestershire
    The cable supplied with the p5 are reasonable quality (42strand I think) terminated with single rca phonos. These cables connect the satellite speakers to the sub/amp. I believe you would need to provide a single 3.5mm stereo to two rca phonos to run the speakers. You can pick one of these up from any high street electronics store or a hifi specialist if you want a better quality lead.
    The manual is available in pdf format from:
    http://www.acoustic-energy.com/products/aego/aego2manual.pdf
    If you want to get an idea of what you're getting.
    Hope that helped
    Gaz
    -x-
    BTW there's also a stereo jack on the front of the sub :)
  3. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    Thanks Gaz!!
  4. gaz.thomas
    gaz.thomas
    Dec 17, 2002
    62
    Worcestershire
    Have you got them all rigged up yet - how're they sounding?
  5. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    They came about an hour ago - all set up in the study.
    My computer sounds good!!
    Very, very nice little speakers
    I don't think I'll be replacing my main stereo's speakers with them, but I may well have to get another pair for my bedroom!
    I'd have been happy with them if I'd spent a lot more than £100 on them!
  6. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    and they came with a selection of leads - so I didn't have to buy one!
    I got a phono-phono lead, a 3.5mm-phono lead and a 3.5mm-3.5mm lead.
    And wall brackets - what a great little package for £100 - can't go wrong!
  7. Art Vanderlay
    Art Vanderlay
    Apr 9, 2003
    87
    +3
    Do your speakers hiss when there is no sound going into the Aego2?
    I have an Aego2 with an extra centre speaker as my front 3 speakers in my Home Cinema set up. The left and right speakers hiss with no input, and the centre has a hiss and a slight hum. This is particularly irritating when listening to stereo sources as there is no sound going through the centre to drown it out.
    I thought at first that it might be due to ground loop hum but I ruled this out.
    I understand that the Aego5 system had a similar problem which was solved by a power supply mod - moving the transfomer outside the case.
    I am sending my sub back to AE so hoefully they will solve the problem for me.
  8. chez
    chez
    Feb 25, 2003
    1,630
    41
    Dallas, TX
    +19
    it does have a very slight hiss if you put the volume above half way, which is slightly annoying!
