AE900U picture pixelating while watching cable TV
F
forced347
I just installed a AE900U and when I am watching cable TV (HDMI/DVI) the picture pixelates. I have a Motorola 6200 HD cable box.....if I use component video the picture is fine. How do i fix this??? Thanks in advance.
F
forced347
Let me clarify...if I use component video with a DVD player the picture is fine. I haven't put the component on the cable box yet so it could be the box or digital input(try that tonight)
Anim
Ah in that case my original reply might still stand in that the signal from the cable provider might be low quality as some channels are low bit rate. If all channels are the same then this probably isn't the case tho.
F
forced347
Thanks, I called the cable company and they will be out tomorrow to check things out.
