AE900, Z4, TX200, TW600 Side by Side Comparison
Discussion in 'Projectors, Screens & Video Processors' started by Anim, Sep 21, 2005.
  1. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    I just created a new article comparing these projectors side by side if anybody is interested in viewing it.
    Link direct to article here
    Ta
    Anim
  2. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    thats great. I will keep that bookmarked if you are going to keep it updated. Not sure if it is a page problem btw but the epson stuff is impossible to read cus you have other txt over the top of it.
  3. Boftas
    Boftas
    I saw in the list that you put Scart = No on Panasonic PT-Ae900. In Europe it will have Scart.
    /Peter
  4. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    I've updated the AE900 to include Scart.
    Dont know why you have an issue with the layout dapex. Im using IE6 and FireFox to view the pages and it seems ok for me. What browser are you using?
    I keep it updated as much as I can, mostly try to add a few things each day when i browse the net.
    Anim
  5. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    I have also read somewhere that the AE900 can do contrast ration 7000:1 in Vivid mode and also read in another article that the Z4 is 5000:1 not 7000:1 but Im sure these will get cleared up when the reviews start appearing.
    Anim
  6. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    I see same thing - IE6...PJ :)
  7. dapex
    dapex
    Jul 21, 2003
    1,082
    38
    +11
    ie6.
  8. Mark_a
    Mark_a
    May 27, 2005
    3,064
    +612
    I'm using IE6 on WinNT sp6, if that's of any interest, and I see text all over the last column making it unreadable.
    Regards
    Mark
  9. gingercat
    gingercat
    Nov 19, 2002
    490
    Lancashire, UK
    +27
    For those with viewing problems, either make your window wider and the right pane will no longer overlap, or make the window narrower, and the right pane will appear above the crucial table.
  10. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    :smashin:
  11. Mark_a
    Mark_a
    May 27, 2005
    3,064
    +612
    Doh! Wouldn't have happened on my widescreen laptop, but am stuck at work at the moment with my crappy old computer and it's 4x3 CRT monitor.
    Regards
    Mark
  12. monopole
    monopole
    If you're using firefox, install the web-developer extension and temporarily disable the styles to see the table clearly.
    Maybe the div containing the table could have a z index to place it above the right hand div...?
  13. scumball
    scumball
    Jan 12, 2004
    6,465
    Harrow - London
    +440
    I bet the European 900 model won't have 2 Component inputs...just one and the scart.
  14. inzaman
    inzaman
    Dec 16, 2002
    7,959
    Derby
    +1,023
    Its a shame they dont drop one of these and have another HDMI or a DVI, imo.
  15. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    Anybody seen a European model yet? Would be nice for a few screen shots i suppose.
    Anim
  16. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    I've just noticed that the Z3 and Z4 use the same W bulb. Does that mean all you free bulb users from the Z3 deals can sell that spare bulb and save even more money or use it in a Z4. Im still on my AE100 and havent replaced the bulb!
  17. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    Anyone know what the 'confirmed' rated life is for the bulbs in the new AE900 in low and high lamp mode. I think I read 2700hrs in high lamp mode with the chance of slightly more if using the dynamic brightness thingie. No mention of low lamp mode though which is what I would run mine in (along with high fan @ 24db woohoo!! to achieve my runtimes of 10000hrs in 2.5 years! LOL )
    Can we extrapolate that if the bulb lasts 2700+ hours in high lamp that it should do nearly 6000 hours in low lamp? Why has the low lamp figure not been quoted I wonder??
    On a sidenote, I am about 200hours away from the magic 10,000 hours on my Ae300. Unfortunately or Fortunately depending on your or my point of view, my Ae300 still looks great to my eyes with no panel burn/heat staining and little noticable decrease in brightness to my eyes undoubtably down to few on/off cycles due to long runtimes and low lamp/high fan.
    Therein lies my problem. I want to upgrade but can't seem to bring myself to junk a perfectly good Ae300!! :D
    My current plan which I suppose is a win win situation is not to replace my current bulb at 5000hours but to merely reset the counter with the current bulb still in situ, and see how many more hours I can get out of it. (Still plenty bright to my eyes) If it dies silently after getting a few more hours out of it then I will repeat the process with my old first 5000hour bulb that I still have in a box and see how much extra I get out of that. If they both go silently with a few more hours in the bag then great. If one or both go explosively taking the PJ with them then also great. I now have an excuse to get an Ae900!! :D
  18. jriihi
    jriihi
    Mar 6, 2005
    196
    16
    Heh is that confirmed that 22db in low lamp mode for AE900?
  19. BOKERON001
    BOKERON001
    Somebody knows as it will be the price of the different lamps? :rolleyes:
    Regards
    Pd. Hello everybody, it´s my first post here :hiya:
  20. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    Hi Calibos :hiya: Nice to see someone else actually using their PJ. I've clocked 3850 hours on my AE700 in 11 and a half months and bought a replacemt bulb for £92 :D I'm going to go down the route of keeping the old bulb in, reset the hours when it goes off at 5000 hours and see how much I can get out of it! :D
    P.S. Don't you just hate these people who have a PJ for 3 years and have 50 hours on the lamp!! :confused:
  21. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    Quoted in a review
    Snip:
    Projector Noise:
    I can't recall the claim, but it has to be down around 22-23db - in full power mode. It is the quietest projector I have tested to date, quieter than the BenQ PE7700 and the Optoma H78DC3. Noise - is not an issue, period!
  22. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    Just to let you guys know, there is now a 10 page spec sheet up for the AE900 on the site.
    Will keep the page updated as I get more information for each pj.
    Anim
  23. calibos
    calibos
    Aug 4, 2000
    931
    Ireland
    +33
    Tell me about it! You wonder why they bothered with a PJ in the first place. I think a lot of people figure that if they use it too much they will lose the WOW factor. I mean I think I am a little like that with a lot of things ie. I find the novelty of a lot of things I buy wears off quite quickly. For some reason though, I still haven't lost the WOW factor with the PJ even with it being on 9 or 10 hours a day. Sure when I am just watching something on Discovery I'm not getting goosepimples but every time I stick in a new DVD and the 6.1 kicks in and the movie starts I seem to quietly giggle to myself like a kid, "holy s***, I'm watching this on a 7.5ft screen, muahahaha!" :D
  24. Anim
    Anim
    Feb 2, 2002
    1,682
    Cheshire
    +62
    LOL :thumbsup:
    I still get that excited feeling too then the other half will say (on queue) Can you turn it down a bit, I have a headache.
    Its a ritual.
    Anim
  25. paulmcp2403
    paulmcp2403
    Mar 29, 2005
    1,357
    +142
    DEANO B - where did you get an ae700 lamp for £92 ??????????
  26. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    OOOOH I thought 'turn it down' was part of the standard DVD intro along with the Dolby/DTS sound demo. :)
  27. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    Ha ha! I knew this would come up! I was lucky enough to stumble upon it on Ebay. I had been looking for one for a few weeks and £235 was the cheapest I could find it for :D I had much trouble with the seller though and had to wait 4 weeks to get it. I've tried it though and it works fine and is definatley a new bulb :smashin: Now all I need to do is find another because I'll need one at the end of next year :rolleyes:
    P.S I also bought a new Black & Decker wallpaper stripper for 99p of him :thumbsup:
  28. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Where does that fit into the AE700? :confused:
  29. Mark_a
    Mark_a
    May 27, 2005
    3,064
    +612
    It's difficult as it got a bit bent falling off the back of the lorry. :)
    Regards
    Mark
  30. DEANO-B
    DEANO-B
    Oct 15, 2004
    516
    Leeds
    I bought the bulb of a bloke off Ebay, and I also got the B&D wallpaper stripper stripper of him. Just saying I got a 2 good bargains :clap: . Makes a change as I usually get ripped off!
