AE700 works fine... except with Star Wars DVDs!
Discussion in 'Projectors, Screens & Video Processors' started by joffonon, Oct 5, 2004.
  1. joffonon
    joffonon
    Dec 4, 2002
    115
    Westcliff-on-Sea, Great Britain
    +4
    Thanks to Ben, I got my AE700 yesterday. As a projector newbie, I have to say I'm so glad I plumped for this one, as the out-of-the-box quality is just stunning. :thumbsup: No dead pixels, no vertical banding to my eye, and certainly no screendoor. I tweaked the flicker settings on the service menu after it had been running for an hour or so, but only minor adjustment was required (no more than one or two notches up or down on each colour adjustment).
    But, I have a problem that's annoying; naturally, the first DVD I tried out was Star Wars (Region 1), from a cheap-and-cheerful Sony DVP-NS305 player, whose RGB SCART output works perfectly on my 32" TV. The menu screens look fine, but as soon as I start the film itself there is flickering horizontal interference that renders it unwatchable. Go back to the menu screens, and all is well again. The same is true of the other two films in that set. The other Region 1 DVD I had to hand worked fine (THX-1138), as did a Region 2 DVD (a Doctor Who disc) and the RGB SCART output of a Sky+ box. I couldn't test any more discs as they're piled up elsewhere in the house awaiting shelving to be fitted this week!
    The problem goes away if I change the DVD player's SCART output to 'Video' (I'm guessing composite), but obviously the picture isn't quite as good as RGB (though still watchable).
    Am I right in guessing that there is some sort of copy protection on the Star Wars DVDs that is causing this RGB problem? I've heard of the problems Macrovision can cause projectors, but it surprises me that THX-1138 isn't similarly protected. Unless there's some sort of new protection on the Star Wars discs.
    Grateful for any opinions. Fortunately, I'm planning to go down the PC route anyway, so the annoyance should hopefully be only short term, but it's still annoying nevertheless! :confused:
    Jonathan
  2. Darwock
    Darwock
    Hang on, what sort of problems do PJs have with macrovision? That's ridiculous if it's true.
  3. jerab
    jerab
    i had the same problem as you when i popped the first dvd into the just-out-of-the-box 700, it was a Moulin Rouge region 2. I used the scart that was previously attached to my cable box. I was horrified to see the distortion :eek:
    I thought to myself this can't be right so went straight down to richer sounds the next day and got myself an expensive component cable. The picture is now stunning and the colour is vivid :rolleyes:
    I guess it was money well spent.
    Jeremy
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    AFAIK Macrovision screws-up the recording of analog signals by a VCR etc, not their playback on a display ... I don't see Macrovision is the cause of your problems here.
  5. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    I wouldn't jump to too hasty a decision to discount macrovision as the cause. IIRC it works by sending pulses in the blanking portion of a signal to throw video/DVD/HDD recorders. Unfortunately this pulse throws the Automatic Gain Control circuits (constantly adjusts the input signal to keep at optimum output level) which are used by recorders, but can also be found in some displays. This is usually fine and I don't think it that likely to be the cause, but it still might be worth giving the Keene macrovision blocker a quick try just in case...
