AE700 - What screen type is recommended ?
Discussion in 'Projectors, Screens & Video Processors' started by Beano, Oct 13, 2004.
  1. Beano
    Beano
    Getting a AE700 soon... so I'm wondering which screen type is best, white or gray ?
    Read somewhere that gray is best for LCD projectors - is this correct ?
  2. Beano
    Beano
    *BUMP*
    Does anybody have any thoughts on this ?
  3. Tempest
    Tempest
    Jan 11, 2002
    6,451
    Horley, Surrey
    +1,678
    I think simply put.
    If you use grey as a screen colour over matt white
    You will get slightly better blacks at the expense of some screen brightness.
    I experimented with greys (via the well known dulux icestorm route) and yes, blacks were less grey, but I could not live with bright films being pulled down a bit, so I stuck to white screen in the end.
    Personal preference I think.
    Best would be to get a sheet of white coated hardboard (under a fiver)
    and have half white, half grey (icestorm paint of your choice) hold it up in front of your projector and see what you think.
    Total cost under a tenner.
