AE700 via component - best settings?
Discussion in 'Projectors, Screens & Video Processors' started by CooperUK, Aug 5, 2005.
  1. CooperUK
    CooperUK
    Jun 30, 2003
    2,168
    Hampshire
    +289
    Hi all,
    I've just set up my panny with a component cable from a prog scan DVD player. Any suggestions for best settings?
    Much appreciated for your help. BTW, I am also using a Hoya filter.
    Cheers :thumbsup:
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,089
    38
    NW London
    +9
    I dont think there are any 'best settings to be honest'. Its dependent on the filter used, the source used and probably varies from one AE700 to another.... A quick go with AVIA or DVE would get it looking good.....
