AE700 thrown distance compared to 300.
Discussion in 'Projectors, Screens & Video Processors' started by Bristol Pete, Oct 4, 2004.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    hi,
    Never one to bog myself down with technical details, as never really sure, but can anyone tell me if the throw distance if the AE700 is similar to its older brother the AE300 which I own.
    I think the 300 is classed as a short throw lens. Is the 700?
    Thanks,
    Cap :)
  2. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Just had a look on projector central and although the 700 has a greater range it can cover that of the 300
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    Thanks Jon.
    Top work.
    Cap :)
  4. clockwork
    clockwork
    Oct 13, 2002
    42
    Edinburgh
    Sorry to hijack but I have a query related to this one.
    Does anybody know if the replacement lens' on the AE300 will work on the AE700?
    The specific lens Im interested in is the extrat short throw lens (LECWE300).
  5. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    hi all .i ve checked projectorcentral calculator for the 700 and it says i will get a 76" diagonal picture from 15.3' .what i want is an 88" diagonal from this distance .
    does anybody else with a bit better understanding than me know if i will be able to achieve this. thanks andy.
  6. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,147
    41
    NW London
    +17
    yup - you can get anything from between 76 inch diagonal and 149 inch diagonal depending on whether you sue 1.00 zoom or 2.00 zoom (or between... :) )
    You can get an 88inch screen from anything between 8'9" to 17'9" from the screen.
    chris
  7. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    :thumbsup: cheers #6 i was beginning to sweat there after id ordered one.
