AE700 removing Lens-shift lever
Discussion in 'Projectors, Screens & Video Processors' started by Folketing, Jul 20, 2005.
  1. Folketing
    Folketing
    Does anyone have an idea how to remove the lens-shift lever on a AE700. Without removing, i can not open the case of the projector.
    Thanks in advance
    Folketing
  2. lonewolf
    lonewolf
    Jul 12, 2003
    13
    Taken from service manual :
    6.2. Removal of Upper Case
    1. Remove the cap of the lens shift lever.
    2. Unscrew the nut in the shift lever.
    Note:
    - Turn clockwise to unscrew.
    3. Turn the shift lever counterclockwise and remove it.
    4. Turn the projector upside down.
    5. Unscrew the 7 screws.
    6. Return the projector to the normal position.
    7. Remove the upper case.
    Hope that helps.
    lonewolf
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    You don't happen to have access to the service manuals of other PJs do you?
    eg Hitachi PJTX100.
    Just in case I ever need to remove the case!
    ...PJ :)
  4. Folketing
    Folketing
    Many thanks!!
    Hope I can find a tool for the screw.
    Folketing
