AE700 remote control sensor is only on front of unit?
Discussion in 'Projectors, Screens & Video Processors' started by tjobbins, Jan 1, 2005.
  1. tjobbins
    tjobbins
    Jan 1, 2005
    162
    16
    Harpenden
    Hi all,
    I had a look at the manual for the AE700 and noticed that there only seems to be a remote control sensor on the front of the unit.
    How does this work out when the projector is situated in front of you? Do you have to bounce the signal off a wall?
    Tom
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    Think you'll find you can point it virtually anywhere and it will work fine, TX100 remote sensor is similarly placed and I sit behind it, pointing the remote at the screen always seems to work. Presume it bounces around...PJ
  3. Bogeyed
    Bogeyed
    Nov 12, 2004
    79
    Holmfirth,West Yorkshire
    I have my Z3 mounted above my viewing position,it also has a front remote sensor and works perfectly by pointing the remote control at the screen. It also seems to work ok by pointing it up towards the projector at a 90 degree angle so I guess they seem to be fairly tolerant of aiming position. The handbook mentions critical angles but I have had no problems so far. I would think the AE700 would act in a similar fashion.
  4. tjobbins
    tjobbins
    Jan 1, 2005
    162
    16
    Harpenden
    Thanks guys!
  5. Hal
    Hal
    I have a panny ae700 pj. And it is celing mounted behined me. I just point the remote at the screen and it works fine, Never a proplem ...
  6. kballs
    kballs
    Nov 23, 2004
    32
    9
    I've actually seen many infrared remotes that work pointing almost anywhere in the room (opposite wall, ceiling, side wall, etc.) especially if the batteries are somewhat fresh. It doesn't matter if you change direction 180 degrees, it's not going to change polarity :) (even if it did change light polarity horizontal/vertical the sensors don't work this way)
  7. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    is the beam that comes out of an infra red zapper polarised?!?! surely not..... that would be crazy!
  8. jamesgrahamuk
    jamesgrahamuk
    Just point it at your screen.
