AE700 questions
Discussion in 'Projectors, Screens & Video Processors' started by Argentofan, Apr 14, 2005.
  1. Argentofan
    Argentofan
    Nov 30, 2004
    523
    28
    +39
    I've currently using a AE500, but suspect, due to the image flickering, the bulb will shortly be going pop.
    I'm considering putting the price of the bulb towards upgrading to the AE700, but have a few question, which I hope somebody might be able to help me with.
    I've had quite a lot of problems with the AE500 with dust blobs... is this less of an issue with the AE700?
    Is the black/contrast greatly improved?
    My AE500 is wall mounted - are the screws on the bottom of the AE700 in the same places as the AE500?
    Thanks folks!
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,146
    41
    NW London
    +17
    I cant compare with the AE500, but...
    I have not had any dust issues with my AE700, it has been left on its stand and rolled into position when used (currently has 160hours).
    The screws are in the same place according to other people who have upgraded.
    The black level in the AE700 is good for me, if the room is darkish then the picture looks great. As I have said though I dont have anything serious to compare it to other than a few business projectors Ive played with.
  3. Argentofan
    Argentofan
    Nov 30, 2004
    523
    28
    +39
    Thanks for replying. That's good news about the screws - I won't have to buy a new stand :thumbsup:
  4. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,043
    Babel Sensurround
    +207
    I Had a 500 then a 700 and there is a definite step up in quality.
    Holes are in the same place but because of the design of the 700 being different to the 500 you will have to use the lens shift and this detracts from the pq :(
    Adrenochrome.
  5. Argentofan
    Argentofan
    Nov 30, 2004
    523
    28
    +39
    Thanks for the info - Have you had any dust blob problems on either projector? And, are the blacks clearly darker?
  6. Spooksta
    Spooksta
    Nov 7, 2000
    3,265
    Planet Earth
    +686
    Why do you have to use lens shift. Could you not change the position of the mount to reduce this?
