ae700 question
Discussion in 'Projectors, Screens & Video Processors' started by mickey, Feb 22, 2005.
  1. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    Hi guys , Does anyone know if the ae700 should accept a 1280x720 50hz signal using a vga cable from my pc using powerstrip? like the ae500 did. I have tried it and my pj just doest display any signal but displays 1280x720 @60hz no problem. any info would be appreciated.cheers Mike
  2. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,052
    Babel Sensurround
    +211
    Interesting you should ask this as i have been trying (without success) to do the same.
    Adrenochrome.
  3. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    looks like it only does it through component and hdmi at the moment will let you know if i find out anything different. Mike
  4. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    Silly question this, but why would you want to do it at 50Hz if 60Hz works?
    Nikumba
  5. Barcoing Mad
    Barcoing Mad
    Oct 14, 2004
    1,501
    64
    Norfolk
    +242
    Micro-stutter issues have been discussed before: PAL DVDs are 25 frames per second, so refresh rate needs to be an integer multiple of that.
    Does 75Hz work over VGA?
  6. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Works over dvi but not vga, spent many an hour trying to get it to work and eventually gave up, dont notice the micro stutters on pal dvd's myself, even on fast pans it looks ok to me. More upsetting to me is the fact that it wont display my pc bios on the 700 but could on the 500 (using an ati 9600se).
  7. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    unfortunately I can see micro-stutter but only on certain type of pans, but I am also susceptable to dlp rainbows, 50hz flashing on crt tvs and sometimes on a friday night Flying pink elephants :rotfl: ;) . cheers Mike
