AE700 picture problem
Discussion in 'Projectors, Screens & Video Processors' started by automatt, May 11, 2005.
  1. automatt
    automatt
    Aug 23, 2004
    14
    3
    I've had my AE700 for around 6 months now, and have been very pleased with it. However, I have recently noticed a red tinge on the right hand side of the picture (when displaying a white image). If I adjust the zoom of the projector (to a smaller image) then the tinge also appears in the bottom left hand corner.
    Anybody got any ideas as to what could cause this, and wether or not this is a warranty issue.
    I have attatched two pictures showing the extremes of the zoom. The white image was produed from the service menu, so is not sourced related.
  2. FoxyMulder
    FoxyMulder
    What mode do you use ? if you are having problems like this try adjusting the colour temperature, the control for this is in the menu next to sharpness and if any parts of the picture are blue or reddish then you should use this to adjust it.
    I use Normal mode and my settings are Colour +1 Brightness +4 and Contrast +4 my Sharpness setting is 0 ( if its set higher than zero u add edge enhancement to the picture ) and i do not alter any other settings, i view in almost total darkness.
    Anyways the Colour Temp control is what you should use.
  3. thfccambs
    thfccambs
    Jul 17, 2002
    18,951
    White Hart Lane
    +5,007
    http://www.avforums.com/forums/showthread.php?t=211193
    Looks like phillfyspoon had the same problem and he sent his of for firmware up grade.
    Might be worth dropping him a PM.
  4. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
  5. ptek
    ptek
    Looks like optical path problem, how did it occur, suddenly, been dropped ?,
    possibly, one of the dichroic mirrows shifted, doesn't look like panel problem, firmware - no, try inputting red only, green only and blue only test patterns to see which optical path is being affected to narrow cause down
  6. cine
    cine
    Hi I work in the optics field and have seen this effect called Green/Magenta shift where there is a shift from white to a cast across a image.
    This in my area of work been the result of a from a front silvered mirror or optical spliter being moved out of alignment. This could be the case here.
    Mike
  7. automatt
    automatt
    Aug 23, 2004
    14
    3
    Thanks for the replies. I did think to myself that it may be something to do with the optics, as the difference in the two pictures I uploaded was purely by adjusting the lens zoom from one extreme to another.
    The unit hasn't been dropped or knocked, as it sits on a shelf on the rear wall out of the way.
    To be honest it may well have been there from day 1 as it is only evident on a full screen white or light coloured image.
    So this being the case what is the best way to send the unit back? Do I go back to the shop or direct to Panasonic. If it's direct to Panasonic how do I contact the correct department?
    I see that a few have sent their units back to Panasonic for firmware updates etc. I am currently runing with 1.03.
    Thanks for your help.
  8. automatt
    automatt
    Aug 23, 2004
    14
    3
    sorry to post again with the same question, but I was wondering if you guys who have returned your panny projectors for any warranty work, have done so direct to panasonic or through dealer where purchased.
    If it was direct to panasonic is their an e-mail or tel no. that I could have.
    Matt
  9. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    8,761
    Babel Sensurround
    +207
    Panasonic 08705 357 357
