AE700 - Lamp gone after 400 hours?
Discussion in 'Projectors, Screens & Video Processors' started by redknag, Sep 6, 2005.
  1. redknag
    redknag
    May 18, 2004
    300
    28
    Wickford Essex
    +33
    I've had a panny ae700 since last october, but only have 405 hours use on it. Tonight it wont turn on. Just clicks...green light..clicks....standby...over & over. No lamp light. Does this sound like a failed lamp or other problem? Any ideas? Not happy.
  2. biglyle
    biglyle
    common problem with the 700
    read the consumer reviews at projector central to see just how common this really is.
    Bulb is toast
  3. redknag
    redknag
    May 18, 2004
    300
    28
    Wickford Essex
    +33
    One start in 5 the bulb "ignites" enough to start projecting an image for a few seconds, then mechanical click and restarts. I would have thought that once a bulb has gone it wouldn't be able to do this. Right or wrong?
  4. biglyle
    biglyle
    It could be that the distance needed for the bulb to arc has become too great and the machine is shutting it down as a precausion against it exploding.
    I advise calling the place you bought it or Panasonic directly.
  5. redknag
    redknag
    May 18, 2004
    300
    28
    Wickford Essex
    +33
    I just called a pansonic service centre near to where I live and they told my that the lamp is covered by the warrantee. I told them that I was sure it was not covered, but they insisted it is. Happy days......we'll see.
  6. neil c
    neil c
    Mar 25, 2005
    537
    +3
    Are you sure you got that conversation the right way round? Thats got to be a first in the projector world.
    If they say its covered I wouldn't argue against it, instead just ask them to double check their warranty on lamps for you, just for reference purposes, obviously.
  7. FoxyMulder
    FoxyMulder
    It clearly states in the guarantee that the bulb is covered for the first 500 hours of use and if it fails before 500 hours you are entitled to a replacement.
    Mind you it also states a timescale too and i'm not sure if thats 6 months or a year but it was all on the guarantee.
