AE700 + HDMI Signal Flash/Break
Discussion in 'Projectors, Screens & Video Processors' started by Nikumba, Dec 14, 2004.
  1. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    When using HDMI with my Pioneer 686 i get a flicker of static less than a second in length.
    Is this a pj issue? If so any fixes yet?
    Cheerss
    Nikumba
  2. sye7euk
    sye7euk
    I had the same issue that started like this then got worse until it crashed the dvd player....
    What length HDMI lead are you using and what make? I had issues with SUPRA at 10m changed to 8m CHORD and the issue went away. I think that the Panny has the issue not the Pioneer player.
    I had the player on a plasma for 2 months via HDMI (2m) and never had a problem.
    Also I think that if you wiggle the connection to the dvd player slightly you will cause this problem to occur which I think is related to the poor design of the HDMI connector ie you cant screw it in like DVI.
    Not sure if this helps you or not but I hope you find a solution soon, I know how bloody annoying it is....
    Steve
  3. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    Its a QED 1m HDMI cable
    Wish there was a definant solution
    Nikumba
  4. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    If it's a "white flash" it may be a problem documented on AVS with the AE700. Go to avsforum.com, Projectors under $3500 and search the official AE700 thread for "white flashes"
    Conor
  5. joffonon
    joffonon
    Dec 4, 2002
    Westcliff-on-Sea, Great Britain
    +16
    The short answer is that no-one knows what causes this. The thinking seems to be that it is an HDCP issue, as PC's connected to the HDMI port are not showing this issue. Whether it's down to the sending device or the projector is a matter for the engineers to look into, but I suggest you complain to Pioneer and Panasonic in the hope that one or both will work out which is to blame.
