AE700 firmware update without going to service?
Discussion in 'Projectors, Screens & Video Processors' started by soulkisser, Mar 6, 2005.
  1. soulkisser
    soulkisser
    I wonder if the AE700 firmware can be updated by the user.
    Does anybody know if it's possible?
    Thanks..
    ___________________
    soulkisser
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    I would highly doubt it as there is nothing to plug it into. Also it would probably void the warranty so not worth it anyway....
  3. CooperUK
    CooperUK
    Jun 30, 2003
    2,241
    Hampshire
    +318
    On the avsforum in the states they confirm that it must be done by Panny.
    Shame really as it would be easier to DIY it if simple enough a process.
    Still, they did collect and return mine free of charge bless 'em.
  4. soulkisser
    soulkisser
    Thanks for the replies.
  5. ptek
    ptek
    Internal connection via serial jig required, so not DYI, most products that
    have flash memory upgrade, fall into the, oops, I made a mistake! and then too late to recover catergory.
  6. hubscher
    hubscher
    I took my projector into the Panny service rep. Asked them to upgrade it to 1.07... two weeks later I got it back. On getting home... The version is still 1.03.... Arrrrgggghhhh.... It is 3 hours to the panny service center.
    I would prefer to upgrade it my self...
    Ps. I have not had good luck w/Panny and their warentees, so I don't care if I void mine... (How do you zero out something that is worth nothing...)
  7. silentbob
    silentbob
    Dec 21, 2002
    122
    York
    +8
    Can anyone comfirm whether this job will be chargeable or not? Is it covered by warranty, or do you think they will only upgrade for free if you are actually having issues?
  8. nigelbb
    nigelbb
    Apr 4, 2005
    5,309
    103
    +491
  9. originalbadboy
    originalbadboy
    Mar 27, 2003
    239
    +3
    I wonder if its just a standard DB9 Female to HD15 Male cable?
    If so, it shouldnt be too difficult to pick up one of those from maplin or similar.
  10. silentbob
    silentbob
    Dec 21, 2002
    122
    York
    +8
    If you look at the screenshots of the cable it looks as if this is certainly not the case. Certainly an intersting way to save space, dual use of connectors is a pretty good idea.
  11. soulkisser
    soulkisser
    wow!!
    it's cool to know that there's a solution for everything in the internet :)
