AE700 320 X 240 display problems
Discussion in 'Projectors, Screens & Video Processors' started by fallwood, Dec 9, 2004.
  1. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    Posted a similar question in the HTPC section but thought it suited this section as well. I cant seem to get my bios screen or any kind of dos screen to display on my ae700, worked fine on my 500 but I just get a black screen if i try to boot a ghost disk or enter my pc bios. Is their a way to get round this as its a totall ball ache having to lug a monitor into the lounge if i need to do any dos or bios work.
  2. dnoon
    dnoon
    I know it doesnt help you but this works fine on mine. The only thing you might double check is to have the projector on before the PC
  3. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    could it be a graphics card problem, my mate also has a 9600 ati and suffers from the same trouble.
  4. Ajax
    Ajax
    Feb 4, 2004
    169
    Hello,
    I suspect that you need to change the EDID setting. I have to on my AE500.
    Ajax.
  5. fallwood
    fallwood
    Sep 10, 2004
    864
    Leeds
    +6
    I'm running through vga so the edid setting is not used. I now suspect it to be a problem specific to the 9600 range of ati cards.
