AE500 to AE700 - lens shift !
Discussion in 'Projectors, Screens & Video Processors' started by chriswhiteuk, Apr 3, 2005.
  1. chriswhiteuk
    chriswhiteuk
    Sep 30, 2002
    242
    Walton on Thames
    +6
    Hi guys
    Been thinking about upgrading my AE500 to 700 to allow me to move the PJ from the centre of the room (in the way) to the corner.
    The reason I have the PJ in the centre of the room, at correct screen height, is to eliminate the need to use any horizontal/vertical keystone and therefore get the best picture.
    Is the Lens Shift any good ? or is a degree of keystone correction needed ?
    [​IMG]
    [​IMG]
    Moving furniture etc about is not a problem, but I'd love to be able to sit in the middle of the room (where the PJ is) so I get the best listening position as well !
    I did have the PJ mounted on the ceiling (directly above) but the reduction in picture clarity was unacceptable ! With Lenshift, could I shift the picture down enough to let my put the PJ back on the ceiling without using Keystone (or should I say maximum keystone) ?
    Chris
